NEWBIE
Rear hub assembly removal w/ discs??
Putting new discs on the rear, one of the hold down spring/cup assemblies was hitting the back of the lugs, poked around at it and now its all the way out.... I've got the four 14mm bolts that according to pg 36-11 hold the hub assembly in place out but the hub won't come off, is there something I'm missing that's still holding the hub on there?
NEWBIE
Nvm just wasn't giving it a hard enough pull; now just to get that stupid spring/cup assembly back together....
