You are unbelievable… YES THE ENTIRE ECLIPSE 97-99 GSX “AWD” REAR SUBFRAME WILL BOLT UP TO AN 8G GALANT REAR. PROVIDED THAT YOU WILL INSTALL NEW BOLTS THAT HOLD THE SUBFRAME TO THE BODY. YOU WILL HAVE TO CUT HOLES IN YOUR TRUNK AND IN THE REAR WHEELWELLS TO DROP THE NEW BOLTS IN.
EXAMIN MY BUILD THREAD: https://www.thegalantcenter.org/show...!!!&highlight=
