NEWBIE
Climate control temp not right, P2100, P3100, C1104.
I'm in Michigan and according to the dash display the outside air temperature is currently 122. This seems to be causing the climate control to not want to blow hot air. I used torque light on my android along with one of the $13 Chinese OBDII bluetooth devices to check the codes. It gave me P2100, P3100, C1104. Torque is showing my intake air temp at 86, I'm not sure if the temperature of the engine bay would warm the intake air up that much before making it the sensor. It's currently 33 degrees out.
