Thread: VR4 AWD transmission in FWD car ?
Showing results 1 to 6 of 6
    Hello guy's i'm new to the forum, U have EU Galant 8 2.5V6 tiptronic gearbox, its a 4spd auto, i got a 5spd auto from VR4 but its AWD, is there a way to make it FWD only and use it in my car, the engines are 6A13 and the bellhousing is the same for the 2 cars, i think i'll need the transmission ECU as well. I've searched the internet but didn't find a photo example of someone doing this. The reason i'm doing this is simple VR4 5spd auto has better gears and car will have better mileage, and acceleration with it :)
    Personally I dont think you can make a AWD be FWD, even if it bolts up.
    But ill let the people with more knowledge chime in.
    You may be better off doing a full awd swap if possible.
    i could just be talking but i heard somewhere you could just plug up the rwd portion of the awd system to make it run as if the rear wheels were not active
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    Its easy yes but u gotta know how to weld and a new tank is also needed. Doin this atm
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
    what tank ? i'll nod welding it by myself, thanks for replay
    04-14-2011
    Iceland
    533
    If u really want to make it fwd u can weld up the transfer case and close the hole for the rrar drive shaft... but its a waist of a good transmission imo
    Old ones
