Thread: 272 cams with kia head swap
Showing results 1 to 11 of 11
    New Member BLOCK8732's Avatar
    10-08-2012
    Tappahannock Va,
    75
    Has anyone used 272 cams with their kia head swap, if so which brand did you use
    i have HKS 280.
    Jigz-TGCIL Sosick Motorsports
    08-18-2004
    Charlotte, NC
    1,029
    do you mean on stock kia springs? if so, they are like dsm valve springs and won't like any cams over 10.5mm of valve lift on them. Crower(not Brian Crower) 272 is about the only cams that will work with the Kia valve springs but most people don't use Crower cams these days.
    Kind of best if we knew of your goals to help you better.
    1994 GS FYI
    DSM/CSM Manuals
    10-08-2012
    Tappahannock Va,
    75
    No no no with upgraded valvetrain. Just want to know how the cams were working out and which brands people were using
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by BLOCK8732 View Post
    No issues with using Hyundai/Kia head with upgrade springs. What kind of "272" cams are you planning to run? Some people use Kelford, others Brian Crower, some stick to HKS or JUN, while others prefer GSC.
    1994 GS FYI
    DSM/CSM Manuals
    10-08-2012
    Tappahannock Va,
    75
    Found a set of GSCs I'll get those.
    I would love to hear what the kia head would sound like with a set of GSC S3's...
    10-08-2012
    Tappahannock Va,
    75
    Yea you and me too
    Sounds pretty good.. I have the kia head with GSC R2 cams, they are the S3 for the 2.4 setup
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    And I have gsc s3s on the evo set up. I don't think they would sound that much different, would they?
    Sent from my DROID RAZR using Tapatalk
    10-08-2012
    Tappahannock Va,
    75
    Probably not
Tags for this Thread
