Bad vibrations
Ok my 99gallant DE2.4L
HAS a bad vidration that showrd up after putting on a new/used head. I than replaced the the timing belt, yhe only reason i didnt replace it earlier is that it was done two years ago , also replaced the front motor mount. And i still have the vidration the belts and tensioner and dampeners seem to be alright . Ive had my girl/car since 05 she has seen us through alot and never let us down including the passing of our 19yrd daughter. So im not ready to five up on her just yet. Oh she has 200,012 miles. Anyone have any suggestions. Im thankful for any advice.
Hershman
NEWBIE
Ensure that your oil sprocket is properly timed. Just because the timing marks line up doesn't mean it is in time, due to some reduction gearing it can be 360° out of timing. This would cause vibration issues.
Thanks Rage.
I was able to fix the problem. It turned out to be the passenger
side motor mount. I thank you again for the help.
Hershman..
