Thread: Trans problem
Showing results 1 to 9 of 9
    Trans problem
    Okay, replaced trans and torque converter car would drive and start shuddering(jumping) got a cel for solenoids so replaced those. Also went ahead and replaced motor mounts. Put new fluid in, it started perfectly smooth went to go in drive nothing. Revs up to about 3-3500 and boom engages and moves, then the rpm drop but car won't go until rpm match back up. Same thing in reverse. No cel now.
    What do you guys think??
    Diego
    03-12-2012
    Manvel Texas
    1,171
    Possible torque converter.
    Going to attempt one more fix and I will post tonight the outcome
    Diego
    I've got the trans to drive and work reverse fine but I am still getting a p0750 and p0755 code upon second gear tries to engage. I have the new solenoids in and harness looks in good condition. I've checked e harness to the trans and also the plugs. I have no clue what else it could be. The solenoids I pulled out have 4ohm of continuity. So they were fine from the getgo.
    Diego
    Is the year of the transmission correct for your car? Is the trans fluid still clean at this point?
    Yes and yes.
    Diego
    did you ever find out what the issue was? im having a similar problem with my car.
    I put the 02 trans. 02 ecu and then foind two wires to be different in the harness. Fuel and something else had to be swapped over.
    Diego
    Experienced TGC Member AVERAGE's Avatar
    02-09-2006
    Raleigh,NC USA
    1,085
    I know your car is a v6 but are 02-03 4 cyl trannys the same?
