NEWBIE
Swap
I have a 03 galant, I'm going to do a 5 speed swap, and I wanted to know does the eclipse have to be a 4 cylinder, because I found an eclipse manual but it's a 6 cylinder, does it matter??
Sent from my SM-N910T using Tapatalk
If yours is 4 then it needs to be off a 4 cylinder eclipse.
NEWBIE
Alright thanks
NEWBIE
I got a whole eclipse waiting to be taken apart to do the swap, but I don't want to get an engine light, and I don't kow how to prevent that
search is your friend. did you try that option yet?
NEWBIE
Yes I have, they all say all get an engine light unless I change the ecu
There's your answer, change the ecu. If there were other ways to do that then I'm sure it would say that. If you've got an entire parts car, take the ecu, wiring harness, ignition cylinder and whatever else you'll need.
Check my post, I bought a parts car and swapped literally everything
Sent from my SM-G925T using Tapatalk
