Thread: Are Lancer Evo seats compatible with galant
Showing results 1 to 8 of 8
    Hey everyone the local junkyard has s 2011 Evo with some nice seats in it I wanted to know if I can easily swap the seats or will I have to completely remove everything to get the new seats in? I'm hoping they would just go on easily the seats are not automatic or anything so no wiring should be needed
    - - - Updated - - -
    Btw I only want to get the front two seats
    You will need to make your own brackets in order for them to fit.
    What I did was made an adapter plate to bolt the Recaro to the Galant seat rails.
    Quote Originally Posted by M-Rod View Post
    Do you have a thread about the adapter you made or any pictures my step dad's a machinist so he could help me make a bracket or adapter I just need to know what to do to make it work and then I'll talk to him I know I can pull 2 front seats out of a 2011 Evo for like 120-130$
    - - - Updated - - -
    I think it's like 120 per seat
    That's dirt cheap! I would jump all over that if I were you.
    Unfortunately I don't know of a thread and I didn't take any pictures. It isn't much though. Just flat steel with holes drilled in it for bolt mounting.
    If I score the seats I'll post pictures here in this thread to keep you and the rest the forum updated
    they have threads on it from club3g. just do a search on there for evo recaros install. I originally did what everyone else did with using flat steel and making holes to make it fit but I didn't like how they sat because the rear of the seat sat low. I just ended up going through wedge engineering and ordered a set through them. took a few days to get them and 15 minute install on each seat. if you go the wedge engineering route, take the rails from the recaros also because the brackets are setup to use the Evo rails.
    Quote Originally Posted by dronesurfboards View Post
    Thanks man appreciate that I'll look into that but might give the bracket a try first to see what I think
    TGC Lifetime Patron Solviss's Avatar
    12-04-2013
    Jacksonville, Florida
    260
    Definitely not a straight bolt up. What I did for my recaros was fabricate my own bracket
    Sent from my SM-G925V using Tapatalk
