Thread: Cruise Control Problems
Showing results 1 to 5 of 5
    My 2003 Galant (4cyl) with 130,000 miles cruise control light stays on all the time and I cannot get the light to go off or the CC to engage. Every once in a while, the CRUISE light will randomly go off on the display without me touching the switch and will randomly come back on.
    Here's what I've done to try and fix the problem:
    1. Checked the fuse (fuse is fine)
    2. Checked the vacuum hose from the throttle body to the black box but to be honest I didn't really know what to look for. The hose appeared to not have any leaks or cracks and sealed well.
    3. Examined the black box that the vacuum hose connected to but there again I didn't know what to look for.
    4. I do not have LED tail/brake-lights except for the one on the spoiler and I think those are stock.
    I'm at a loss and do not know where or what else to look for.
    Thanks.
    Try pulling the cc fuse and reinstalling it. That might reset everything
    Sent from my SM-S820L using Tapatalk
    Unhooking the battery sometimes resets things you wouldn't believe
    When I have electrical problems, The first thing I do is make sure I have a good ground from the battery it never hurts to clean things up.
    Check or redo both of the battery terminal connectors. They are both notoriously bad. I had to add a groove and copper wire to the post with a matching groove in the new terminal so it would not vibrate off the post.
