A/C Compressor
Will a A/C compressor from a 90 MITSUBISHI ECLIPSE 2.0 turbo fit a 1991 Galant 2.0 non-turbo. Thanx
it SHOULD.
no garantees, though.
heres an easy way to find out, call your local parts store and ask for the part numbers for the two a/c compressors if they're the same then yes if not then no
t/e/l(d21/22/27) is MB609192
galant(E33/38/39) is MB630355
on a galant vr4, the t/e/l will NOT bolt up.
