hello...
does anyone know what the part number would be for the stock shifter stalk...? and how it connects...? can it be replaced easily...?
i want to use this Momo knob i got, but need to get a new stalk, and hack it down so that the knob does not sit way up on the stalk...
any info would be appreciated...
hello...
try contacting del ray mitsubishi or don herring. even though u don't have a part number they will find it out for u and give u the best deal. you might need to supply them with a description and/or a picture would help too
it's just held on by a couple of screws that go right into the metal stalk but there is that white plastic in the middle of the metal pipe that releases the shifter so you can change in and out of some gears.
I would just take a hacksaw to it and just shorten it but you would have to figure out how to disassemble the whole thing first so you don't mess up the plastic lever in the center of the metal pipe.
