Go to autozone and get it scanned.
Yo my service engine light stays on and i just got the car it only has 35k on it can so one explain this?
It could be a number of different things. If you just installed an intake or some other mods it could be messing with your ECU. Try disconnecting your negative battery cable for about 10 minutes...that should do the trick. IF it doesnt...then go get it scanned like Cdaw said!!
Also there is a specific forum for car problems...so I will move it there...please post in the right forums from now on please!! Thank you
Marc :mg:
did u do anything recently to your car lately or notice anything different in your caar. ie the way it runs...
