My stock head ticked only 55k on it. And the 3g lifters are a direct replacement for the 1g/2g dohc setup I *THINK* they fit the SOHC but im not 100% sure. They are expensive from mitsu, they pop up on ebay alot for aruond $150 a set (16 lifters).
If you ask me its not worth the trouble to install them unless you are rebuilding a head.
And I religiously use the ATF in the oil about 200 miles before I change the oil, I use whatever ATF is cheap =D The bottle it comes in is 1 quart, use a little less then half the bottle.
Rob
