7g ECU pinouts for O2 sensor
I PM'ed Jip but hasn't responded yet...just seeing if anyone here has it. I need to ECU pinout diagram of where the O2 sensor pinout is on a 96 Galant. I am not sure if 2g ECU O2 sensor pinout is the same on the 7g...just want to make sure.
Seth...you have alot of Galant ECU info, help a brotha out 8)
this is for 98, for 96 color may be different, but the connector should be the same
55 Rear Heated Oxygen Sensor (White)
56 Front Heated Oxygen Sensor (White)
84 Rear Heated Oxygen Sensor Heater (Black)
90 Front Heated Oxygen Sensor Heater (Yellow/Blue - cali, Black - fed)
btw, 2G turbo eclipse uses the same connectors, but different numbering system
give me your email and i'll send you eclipse and galant ecu wiring diagrams
Thanks Russian7G! I checked the manual Seth had set up....you are right on the pinout on the ECU for the O2 sensor's. Thanks...I can finally progress on the setup.
BTW: Thanks Seth! 8)
yup, pretty much the same in my 94-95 service manual
