How the hell did you accomplish that? My G wont start without the MAS plugged in.
alright, so i had to swap my intake for the stock airbox for the smog testing, and when i put it on and started to drive to the smog place, i noticed my idling hell high, like 900-1000, and my car sounded like a rumbling ferrai from the inside , i could tell i had hella more power for some reason. it was like instant response off the line, and almost as if i had added like 20 more hp, and so when i was about to pull up i just remember that i forgot to plug in the lil sensor thing that goes in to the big MAS :oops: , anyone have similar problems?
Drive It Like You Stole It!
7G Erubini Body Kit for sale
<div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>How the hell did you accomplish that? My G wont start without the MAS plugged in.</div>
lmao, idk, but it almost seems like it was a restrictor when i had it plugged in, now it seems like its supercharged or something, its hella wierd
Um....w/o the MAF plugged in, the car will not start or run. How your car was able to run w/o the plug...
My car WILL start with it unplugged. It will even idle fine sometimes, and sometimes it will cause surge.
no one knows how this is possible?
ummm doesnt make sense man... my car can start without the plug but it will surge and idle funny..this is wierd
if your car does run with the mas unplugged, you are going to run rich :? rich rich. if you continue to run like that,
expect
fouled plugs
fouled o2 sensors
horrible gas mileage
when you run with the mas unplugged, you ecu goes into a failsafe mode. where fuel is delivered based on rpm and throttle percent.
airflow is extrapolated from that data, and is overcompensated to protect from engine damage(running too lean)
plug your damn MAS back in and get back to normal.
lol, well my plugs are already shit, probably my 02 sensors too,Originally Posted by DOHCSTUNR
and when the fuel is based on rpm and throttle, what is the rpm and throttle based on?
its based on your footOriginally Posted by Reptile
OWN3DOriginally Posted by DOHCSTUNR
not the rpms, it goes to exactly 1000 rpms when i start it, and never moves from there, and then when i put it in neutral, it goes to like 1400.
BTW dustin, if i would have discovered this earlier, not only would i put a car length on u, but 2 1/2Originally Posted by theblackpearl
dude youre fuckin ridiculous
discovered what? running yor engine w/o an airlfow meter.
might as well bolt on a carburator for your next mod...
with a 10" lift kit, 38" super swampers and a 305 smallblockOriginally Posted by DOHCSTUNR
i guess u guys didnt catch my sarcasim, its not like im gonna leave it off, its just kinda wierd how ive never heard of anyone saying something about this, and ppl saying they cant even run their car without it, let alone get more power.
ya thats strange.
Every car is different. My car ran with it unplugged, but ran like crap. Maybe yours is broken
regardless if you think its making 20hp or not, which i can assure you it isn't, it's not safe and your running your motor like shit
