<div class='quotetop'>QUOTE(datdude305)</div><div class='quotemain'>would that tutorial work on 8 G cuz it say 7 G and i dont wanna get all happy</div>
its the same thing, just don't rely on the pictures for placement
<div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>Will this be okay he ratio is what u stated..
http://216.242.145.16/products/product.phtml?p=10
do you think its worth getting the emange and ditching the FMU..Agian im not gona be doing anything major i just wanna install it and drive..i figure the only reason i get emange is for tuneing..im gona run under 10PSi this is my daily driver,so i dont wanna buy things which i will not use..so if the FMU will do the job im fine wit that and ditch the emange it save me few bucks but if i need it ill get it..</div>
yeah thats what you would want. there is also a model that bolts right to the fuel rail.
electronic tuning is much more precise. once you get it on the dyno, with the emanage you will get a great tune w/ this setup. oncxe you get that tune for your desired psi, you won't really ever have to touch it again.
yes the fmu would get the job doen for a very basic system. but even tearstone will tell you its not as precise. thats why in their better kits they provide the afpr and emanage cause its a much better way to tune.
but tis totally up to you. i offer my suggestions so that you know exactly whats out there so you can make the best descisions for yourself.
<div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'>FYI, the "recommended" gauges for the Tearstone kits are boost, EGT, and fuel pressure, according to the actual builder of the kit.</div>
That is for the budget kits that primarily run on fuel pressure. For the electronically tuned cars, the 3rd gauge could be left open for a nice A/F gauge or Oil Pressure gauge.
-update-BOUGHT Guages
GREDDY
60mm Mechanical Boost Gauge
60mm Electronic Fuel Pressure Gauge w/ Peak Hold and Warning
60mm Electronic EGT Gauge w/ Peak hold and Warning
$457shipped useing mechanical boost
00 Galant ES Turbo/5-Speed
13 GTR
-Update-12/20
Bought the AEM ugeo $220 baby hahah
And russ less me remove the fuel package so no more FMU THANKS ALOT RUSS..
FUEL options now are..
440cc Bosch Fuel Injectors
AFPR+guage
Greddy Emange
17 days till i get the kit![]()
13 GTR
Why not just run an AFPR and an older SAFCI? Can pick one up for around $100 now. Only thing the eManage will do is control timing as well correct? If you want to spend the least amaount and arent going to run high boost, an SAFC would probably be easiest. If you have a few extra hundred to spend, grab the eManage.
here a pic,i got worried when i looked at the boost guage cuz it was in messurements of .5 and i was like wtf how will i kno im at 7lbs...
http://i5.photobucket.com/albums/y151/Iced...alant/turbo.jpg
13 GTR
That gauge is metric, reading in kPa (kilopascal)Originally Posted by IceDouTGaLanT
http://www.santos.com/ConversionCalculator.aspx?p=73
7 PSI = 48.26 kPa
To find that on your gauge:
48.26 x 100 = 0.48
So that would be just below the 0.5 mark.
Yah just measured in bar. 1bar = 14.7ish psi.
AWSOME THANKSSSS ALOT....you guys been a big help to me so far and i like to thank you agian![]()
PS:im getting the Emange with both harness for.....$330SHIPPED
13 GTR
wow...its almost time, kit gets shipped out on the 6th 3-4 days for delivery got everything ordered EXCEPT
Aeromotive AFPR...
Gauge for the aeromotive
01+ midpipe..Goign junk yard tommow,hopefully i find 1
Emange blue with harness...Guy gets this in soon so this if Fine
i need help guys,
i ordered the injectors from russ the same ones stated above with all the hardware which they come with....Im lost on the AFPR, im getting the model
"AER 13109" is that the right one, i believe so since its for DSM's,will this bolt on to the fuel rail directly or will i need to get a new fuel rail??? is so i can get the following really cheep AEM 25-130C PRICE 125shipped it retails 186.98, if i need a fuel rail...and the gauge which mounts on the afpr i cant find it anywhere, is it a particular size for which im looking for?? or can anybody post a site where i can get it..?? that's about all im still confused about, i must say i learn ALOT threw this project haha..
So my fuel system is as follow, let me know if IM missing or I got it dead on.
Greedy emage,
Aeromotice AFPR + guage
Fuel Injector Clips
Fuel Injector Spacers
Fuel Rail Hardware
*any let me kno if i need a new fuel rail or if its worth gettin that AEM over my factory since its on sale?
side note:1000 Post![]()
13 GTR
<div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>wow...its almost time, kit gets shipped out on the 6th Â*3-4 days for delivery got everything ordered EXCEPT Â*
Aeromotive AFPR...
i need help guys,
"AER 13109" is that the right one, i believe so since its for DSM's,will this bolt on to the fuel rail directly or will i need to get a new fuel rail??? is so i can get the following really cheep AEM 25-130C Â*PRICE 125shipped it retails 186.98, if i need a fuel rail...and the gauge which mounts on the afpr i cant find it anywhere, is it a particular size for which im looking for?? or can anybody post a site where i can get it..?? that's about all im still confused about, i must say i learn ALOT threw this project haha..
Greedy emage,
Fuel Injector Clips
Fuel Rail Hardware
side note:1000 Post Â*:)</div>
here's a whole kit
http://www.importevolution.com/product_inf...roducts_id=1620
or you could go with a bolt on
http://cgi.ebay.com/ebaymotors/DSM-Fuel-Pr...1QQcmdZViewItem
^the bolt on still has the parameters for a gauge. probably the easiest to work with.
if it fits on evo fuel rails i would think it would be fine for the 4g64 as well. might want to ask someone like stewi on that.
great so i got the aeromtoive on lock now, just gota find out if it bolts on factory hardware or if i need new rails,
13 GTR
This is a bit pricey ($134 shipped), but it might make life a whole lot easier:
http://www.boomslang.us/extension.htm
Its basically an ECU harness extension that you can wire stuff like the eManage into - doing all that work on the car is a pain in the ass, especially since the wires down there are pretty short and you have to contort to get at the wires. Plus you save your factory harness from getting hacked up.
Might be interesting to see if I can make my own version...
That harness extender is a very good idea. Makes things much easier. could actually install the emanage harness outside of the car hten just connect it. Wish I had that crap for my car!
im gettin it installed perfesionaly do u realy think its needed?? but its a good idea i wish it was like 60-80 bucks
13 GTR
<div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>im gettin it installed perfesionaly do u realy think its needed?? but its a good idea i wish it was like 60-80 bucks</div>
If you are getting it installed professionally then I wouldn't get the boomslang harness. If you were doing the emanage install yourself, on the other hand, then I feel it would be worth the money. I just wish they had it for the V6, as my back was killing me trying to contort under the dash to reach the wires.
If you are getting it installed professionally then I wouldn't get the boomslang harness. If you were doing the emanage install yourself, on the other hand, then I feel it would be worth the money. I just wish they had it for the V6, as my back was killing me trying to contort under the dash to reach the wires.</div>
tell me about it. thats how i felt when i had to rewire my entire 72 pin ecu harness for my 1g ecu. :cry:
after that, tapping for an safc2 was a walk in the park
tron who is a club3g member runing the same kit i got is useing an FMU and he stated
'You won't need to tune the car. The kit comes with an MAS/MAF, whatever it is, modification kit. As the kit comes, there is no need for an FPR, emanage, or larger injectors. The injectors that come in the kit are big enough for the application they are intended for.
I have NO PROBLEMS with the FMU.'
so its got me confused,even russ told me he likes the afpr n emange over the FMU, but do you guys think the FMU will be okay for 8 psi?? if i ever boost up i can upgrade to the emange and afpr? but then i would have to buy an in cabin fuel preesure guage..daym i hate when i think i got a hold of everything and i get new info
But when i go to tearstone.com and see thier new setup and priceing, i see they ditch the FMU and pick up an emange..SOOO im stickin wit the afpr and emange...shyt dont gota tell me twice,wow it was good venting my porblem
13 GTR
