wait isn't that pinoyV6
I just took pics of this tutorial written up in this issue of SUPER STREET mag...
in the article i believe the guys name is Yamzy and thats his 240SX.
note* it also says it should take 10mins/per wheel
so that's pinoys name yamzy... just getting a kick out of it... peace P
what do you get out of this? what is the end result :?
Clearance. Most do that if the tires are rubbing the wells slightly.
MECP First Class Certi-fried installer.
For the right price, nothing is impossible.
ok, so thats not really the best way to get an even roll all the way across your fenders or q-panels.....
you need 2 people for this
dont use a jack
put the car in neutral.....
slide the bat in the well, to the desired roll and angle
slowly roll the car backwards....the tire will carry the bat along the fender
this way you get an even roll......
are there places i can go to get this done? i don't wanna leave mini dents using the first method, and the 2nd method might crack the paint. :?
R.I.P. My fellow Galant owner. May God be with you and your family.
aww f@ck it i i kept searchin and found it its about $50 bucks a fender... can someone do a exact tutorial on this i would rather do the 2nd method(with out the jack) seems like it would be a lot better...Originally Posted by The F.B.I
Go to any local body shop, I don't think it would be that much, plus if they f up, they fix it. If you f it up, it comes out of your pocket
I tried out the baseball bat method it worked pretty well. I needed to roll the fenders a little bit with the 18s and being how low I am.
shogun8g: I feel gay
I did this just last week, I used a heat gun (harbor freight 9.99) and a piece of PVC pipe (2 inch) and it worked very well. I dont have a baseball bat so that's the only reason I went with the PVC pipe. No more rubbing. I didn't fold it all the way across, just a nice roll to clear the tires.
here's a tutorial that I used, hence the PVC:
http://forums.audiworld.com/s4/msgs/1745791.phtml
<img>
Shit you guys are brave.
:shock:
8G 4 life!
Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
i think a 2inch pipe would be safer since the a bat aint even...i don't know...
u r rubbing with stock steelies, FBI?? it has been said that you can rent a fender roller...you know kragen and autozone isn't that far from your pad....
i didn't know they rented out fender rollers, to be honest i thought only custom shops have em, and you would jsut pay em to do it, but i'll look into it...Originally Posted by o1naturalhigh
hmmm I should see if we have a fender roller where a work and maybe roll em out to go for a more aggressive thicker wheel Im sure i could just grab it during lunch and roll it out quickly
