First thing to try is changing plugs/wires, thats wat the recommended fix is. I'm still tryin to figure out why mine is misfiring, but you may just have a regular case and have to change the plugs n wires. Stick w. NGK plugs and almost any wires for your car will be fine. I have Duralast on there, OEM is best, Magnecor makes some, so does NGKOriginally Posted by n3oAcid24
edit: you have Magnecor's, I'd just change plugs, stick w. NGK like i said
