nice write up!
i found that the best way to fill in the extra bit of space between the sleeve and the shock/strut., is to wrap duct tape around the struts tightly and even ly until you can just barely slide the sleeve over it.(might require some very light tapping with a rubber mallet if its snug)
this will help insure that your sleeve won't move around, and helps prevent it from slipping further down the strut.
(picked this tip up in a tuner mag. tried it myself when i ran sleeve-overs. worked great)
