Thread: I went to the DYNO today, Good news and bad news
Page 3 of 3 FirstFirst 123
Showing results 41 to 60 of 60
  1. #41
    sorry brian... as Donovan would say man u gatta keep going... i mean a lot of ppl look up to you.. you have no idea how much this saddens me man.... juz keep going dude... or maybe u can try the 4G64 block from Cali and put the EVO head on it... but if anything keep going... dont give up man... u need to keep going... cuz if you dont your not only crushing your dreams... but alsoo mine.. im so close to the motor already juz keep going....
    Jigz-TGCIL Sosick Motorsports
  2. #42
    08-04-2003
    NY
    4,344
    well I had my friend come over and look at everything. He thinks the block might be salvagable if I get it re-honed. The pistons are junk, the valves are junk, and the head is borderline. The head is going to the machinist tomorrow morning, tomorrow night I should have an idea if its still useable. Tomorrow im going to take off the oil pan and pull the pistons and rods out to make sure the rods arent damaged. If the rods arent damaged, im going to try to just replace the pistons and head and put it back together, if the rods are damaged, then I gotta figure out what to do. Like I said, I really want to rebuild it, but its cost a ton of money and im trying to look forward in my life to things like a house/condo and getting engaged in the near future. I will let you all know how tomorrow goes.
    99' Galant ES
    4G64/63T
    AEM EMS
  3. #43
    07-20-2003
    Orlando, FL
    3,169
    Whatever you do bro...good luck man. I really hope for the best, you put some hard work into that car and it sucks if the end result is what is is now. Though..it sounds like you got your head on straight as far as your future when it comes to the house/condo deal and possible marriage. What ever happens man...seriously I wish the best! :thumbsup:
  4. #44
    Experienced TGC Member DryBear's Avatar
    11-05-2003
    San Francisco Bay Area
    1,517
    Good luck!
  5. #45
    TGC Regular
    06-09-2004
    Maryland/RAF Lakenheath England.
    714
    YES! good luck!
    Donovan J.
    Need something from england..or other eastern nations holla...
    I dont mind looking.
    Car: Toyota Soarer GT-T Jspec "Limited"
    Galant: at home chillaxen :(
  6. #46
    daaaamn brian. i never got to see this beast of yours. i was rooting for u man. i was expecting to see your car in the pages of sport compact car one day. :cry:
  7. #47
    12-17-2004
    Louisville, KY
    4,328
    <div class='quotetop'>QUOTE(Stewi)</div><div class='quotemain'>well I had my friend come over and look at everything. He thinks the block might be salvagable if I get it re-honed. The pistons are junk, the valves are junk, and the head is borderline. The head is going to the machinist tomorrow morning, tomorrow night I should have an idea if its still useable. Tomorrow im going to take off the oil pan and pull the pistons and rods out to make sure the rods arent damaged. If the rods arent damaged, im going to try to just replace the pistons and head and put it back together, if the rods are damaged, then I gotta figure out what to do. Like I said, I really want to rebuild it, but its cost a ton of money and im trying to look forward in my life to things like a house/condo and getting engaged in the near future. I will let you all know how tomorrow goes.</div>
    the way you describe the rest of the motor, i'd expect the rod bearings to be flat.
    hope your conrods are still fine.
  8. #48
    05-14-2003
    Southern California
    1,404
    Good luck dude. Can't wait to see whats up next.
  9. #49
    08-04-2003
    NY
    4,344
    Update. The head is OK, just needs milling and new valves. We thought the block was salvageable, its not. Since the block is no longer good, that means the crank and rods are worthless because everything was custom machined and matched together. still not sure what im gonna do
    99' Galant ES
    4G64/63T
    AEM EMS
  10. #50
    07-20-2003
    Orlando, FL
    3,169
    <div class='quotetop'>QUOTE(Stewi)</div><div class='quotemain'>Update. The head is OK, just needs milling and new valves. We thought the block was salvageable, its not. Since the block is no longer good, that means the crank and rods are worthless because everything was custom machined and matched together. still not sure what im gonna do</div>
    How available and how much are "virgin" E5+ 4G63 shortblocks go for these days? If its affordable for you why don't you just go that route. Stock bottom ends are good for around 400-500whp reliably and thats attainable with a nice setup and good tuning. Its a option that could result on getting the car up and running rather than letting the project go all together and still possibly doing what you are planning to do with a house and plans with your significant other.
  11. #51
    05-25-2006
    New York City
    1,028
    Sorry to here that bro.......are you evo inside on nyccdsm.
    2000 Galant ES = Daily Driver
  12. #52
    08-04-2003
    NY
    4,344
    Yes
    99' Galant ES
    4G64/63T
    AEM EMS
  13. #53
    hey brian dude i know ur planning stuff for the future and more power to you bro but it very much saddens me that ur contemplating on continuing this project i hope u make the right decision for you bro..
  14. #54
    bro sorry to hear that man, why dont you create something here in TGC where people can chip in some money to help you with this man cause fuck it will suck ass to see ur car gone.
    1994 GS DOHC 2.4L 5spd (For Sale)
    1996 S SOHC 2.4L 5spd (Up and Running)
  15. #55
    08-04-2003
    NY
    4,344
    nah man, i got myself into this mess on my own
    99' Galant ES
    4G64/63T
    AEM EMS
  16. #56
    well thats true, but we can all help you get out of it even if its just a little bit.
  17. #57
    08-04-2003
    NY
    4,344
    yea so i took the oil pan off and its completely filled with metal dust, looks like the rod bearings went at the same time is the pistons, this motor is pretty much junk, i got a kid from EVOM coming over to pick it up next week, im gonna part out what I can and then see where I stand
    99' Galant ES
    4G64/63T
    AEM EMS
  18. #58
    Experienced TGC Member Dominicano's Avatar
    07-31-2002
    Fort Worth, TX
    1,418
    Sorry to hear that bro that it has come to this. But its better to have a house and be stable, then to have a fast car. Hope you make back as much as you can parting it out.
  19. #59
    damn bro more bad news.
    well, like dominicano says, a house is always better, especially at a young age so by the time you pay it off its play time again.
    w/e you decide to do good luck. if you part it out completely let me know if there's anything than i can possibly take off your hands...maybe the cams, manifold, etc.
    Cali: Sig 3/28/2011
  20. #60
    <div class='quotetop'>QUOTE(Stewi)</div><div class='quotemain'>yea so i took the oil pan off and its completely filled with metal dust, looks like the rod bearings went at the same time is the pistons, this motor is pretty much junk, i got a kid from EVOM coming over to pick it up next week, im gonna part out what I can and then see where I stand</div>
    good luck with everything bro...
