rivet guns can be bought at ur local hardware store. u open ur doors, put the side skirt how u want it (better if ur not alone). grab a drill, use a bit smaller then the rivet, drill through the skirt and ur factory inside area under the door pannels (area hidden when the door is closed). do it at the front, middle, rear. if the skirt wraps around the wheelwell area, drill there too. then use therivet gun and it locks the skirt on. the rivet, once you see it, is less noticeable, can run flush, and be painted on. if u wana just buy self tapping metal screws u can. use that will a power drill with a screwdriver bit at the end. but with screws they aren't flush, stand out, and people can just unscrew them and attemp to steal it...
