Eh...they're from 1990, and are simply a NA VR4 I believe....alot of them are attempted to be passed off as "pre-badged" VR-4s when guys add a small turbo to them.
<img>
There was an immaculate Galant GSX on eBay a few weeks ago. KBB is something like $510, it sold for over $2,400 haha! I wish it would have stayed around $800, I would have snagged it.
I almost bought one a few months back, To bad back then my budget wasnt as large as it is now, I missed that car by $300.
https://www.thegalantcenter.org/viewt...p=467233#467233
Signature wanted call: 1800-Darkkend
<a>Take Better Photoshots Tips from the Pro's</a>
i'd rock one.
would be a fun car for the winter
love those 6Gens. been going to the junk yard lately saw one of that GSX but been stripped already. I just took the GSX and Galant emblem.
I'm selling my G
they are horribly underpowered, though. I drove a few in my day.
also, the ECS is expensive as hell when it fails.
<div class='quotetop'>QUOTE(ChikagoGTZ)</div><div class='quotemain'>Eh...they're from 1990, and are simply a NA VR4 I believe....alot of them are attempted to be passed off as "pre-badged" VR-4s when guys add a small turbo to them.</div>
(there are pre-badged VR4's though, I believe about 7 from info on galantvr4.org)
The G-GSX also doesnt have the 4WS that the GVR4 does.
AND they have cool little 'pockets' .
One is part of the underdash on the driver's side. & they also can have a pod on the dash for electronic suspension.
SO, if anybody finds one in the yard that has dark grey/ black interior. PLEASE grab the underdash & EMPTY suspension pod for me.![]()
<a href='http://imageshack.us' target='_blank'></a>
'92 Galant LS
'92 Galant VR-4
'92 Galant GSR
'93 Galant S (DOHC swapped DD)
I have a GSX right now, just over 100K on the odometer. Let me tell you, AWD is GREAT! Right now I'm fixing a number of problems on the car, but I've taken almost the whole car apart (it's my project car), so if anyone picks one up, or owns one, just ask me anything you want, if I don't know the answer, I will either know soon, or can look it up (have factory manual).
1990 Galant GSX: HKS Super flow, front strut bar, KYB coil overs, UR underdrive crank pulley, Greddy Kevlar Timing belt, Revolution muffler, custom grounds, Center Force clutch, Fidanza flywheel, Pace setter header, 4 wheel cross drilled rotors
hey, thought id introduce myself in this post seeing as how i just picked up a galant gsx. picked her up for 900 bucks and will soon be boostin her for fun. you guys know some good stores to shop around on for misc. parts ?
www.slowboyracing.com has a wide variety of bolts, gaskets, and other misc parts.
I still want to buy a 6g :(
Welcome, your going to like it, I just bought a 6g VR4.
And Seth there are a lot of 6g VR4's for sale the cheapest ones are just rolling chassis though no motor and or no trans
just a quick question. is there anything different about 4g's in an eclipse an the 4g's in 6gen galants? such as different oil pan or other things of that nature? cause chances are that when this motor pops a 6 bolt will be going in.
pretty sweet though this guy sounds like he is making a nice machine out of this thing
Oil pan is different as your car currently is NA, turbo oil pan will just be tapped for an oil return line. Your motor is the same, just different pistons/rods(I think) and a lack of some oil squirters. The head is the same minus the camshafts.Originally Posted by marc1131
A 6bolt 4g63t will drop into your car with ease, its pretty much meant to be there. You would just have to swap to a VR4 ECu and you would be set.
would the ecu plug right up into the vr4 ecu? or could i just use a 1st gen eclipse ecu.
Buy one then Seth!!!!Originally Posted by marc1131
<div class='quotetop'>QUOTE</div><div class='quotemain'>would the ecu plug right up into the vr4 ecu? or could i just use a 1st gen eclipse ecu.</div>
1g Turbo ECU's and the GVR4 Ecu's are the same.
i see.
The ecu's are the same but beware if it's been sent to a performance shop, or if it comes from a TSi. I have two friends with TSi's and one put a performance tuned ecu from a vr-4 (was wrecked :( ) and it did all kinds of weird things to his car, which would lead me to believe that "weirdness" could happen with a switch in the opposite direction. All I'm saying is, if you are gonna get a new ecu, make sure it's stock and THEN send it in with YOUR requirements of modification, to a tuning shop. It may cost a little more money initially, but could just as easily save you a lot of money later on.
when i get to the point of tuning i will be tuning it with safc on my own. i dont want other people to tune it for me.
