I suppose you could make a bracket to hold the pedal in a different position, though I'd highly recommend making sure that if you do that you don't stretch the brake line or wiring coming into the interior.
i was wondering if there is a way to lower the brake pedal. right now me accellerator pedal is about 2-3 inches lower than then my brake pedal. and my foot sits at a 70 degree angle when resting on the brake pedal, it gets real tiring.
look on page 35-17 in the service manual it shows how to adjust the pedal. not sure if you can get it in the range you want
If that doesn't help you can always get some aftermarket pedal covers and secure the brake cover so it extends down to where you want it.
