Thread: 1g big rods and flexpipe questions
Showing results 1 to 7 of 7
    My first question is are these pistons any good. I won't be using them but I just wanted to know if I should keep them or throw em in the trash. The other 3 are in similar condition
    Second I need a new flexpipe. When i looked at my old one it is 9 inches long so I was wondering if this would work.
    http://cgi.ebay.com/ebaymotors/NEW-EXHAUST...sspagenameZWDVW
    Quote Originally Posted by gravy
    as long as your exhaust pipint is 2.5" wide and you can get someone to cut out the old one and weld this one in, i dont see why you would have a problem
    parting out my 7g project. 1g turbo head with gs cam gears, talon tsi front and rear brakes/5lug conversion. xtc 2g fwd clutch and pressure plate. complete 7g 5spped swap. jdm e54a headlights stock 97 tails, interior trim pieces. [email protected]
    http://www.thegalantcenter.net/forum...211#post477211
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    Dont trash those pistons... Sell them...
    08-01-2002
    North Bay...NorCal
    2,552
    I dont know...is that a huge dent is the side of the piston? I'd trash em...dont think they are any good. Cant quite tell from the pic...got any others?
    08-01-2002
    Keokuk, IA
    8,348
    Need a bigger pic of the pistons. Did the valves hit them? Id assume so, I dont think stock 2g pistons have valve reliefs.
    So whats new with your car? Any updates?
    The reason I ask is because the valves were touching the pistons but. when ran with a new head they didnt hit.
    Yeah ive done a few things and trying to get everything pieced together and installed
    08-01-2002
    Keokuk, IA
    8,348
    As long as they arent cracked they should be fine. You will want to lightly grind down the sharp spots on the pistons, you want smooth angles. My valves hit my current pistons, I just smoothed the tops out and they work just fine. You dont want to grind very much though, just enough to get rid of any sharp edges.
