I tried searching for a tut for rewing your fog lights to switch them on at anytime without turning on the headlights. Can anyone direct me to it or give me some info. Thanks in advance.
Thanks pinoyesv6. I think I'm just gonna get after market fogs, cause that looks a little to complicated for me. Plus I don't want to cut any wrong wires.
Here try this one https://www.thegalantcenter.org/view...092&highlight=Originally Posted by pinoy724
I used this tutorial and it takes 45 min and costs $18Originally Posted by raw0055
[quote="raw0055"]Here try this one https://www.thegalantcenter.org/view...092&highlight=[/quoteOriginally Posted by pinoy724
Dam, that made more sense then the other tutorial, i think im going to rewire my fogz now :D
2001 5 speed 4g64T
[quote="01galant01"]It is probably the easiest mod you will ever doOriginally Posted by raw0055
How can I change the housing to H3 bulbs I want a better output from the fogs so I can get some yellow fogs. I don't like how the 893 yellow looks. Do I just have to change the fuse and plug housing to H3? Will that work.
Basically this is what I was thinking:
I cut of the 893 plug and I replace a H3 plug. Then add a bigger fuse to compacitate the energy pull. But the placement of the h3 in the OEM foglight housing would be another question.
Let me know what you guys would do besides HIDs in the fogs.
Thanks.
i'd get all new fogs. if you put anything other than bulbs that run factory wattage, then you run a big risk of ruining the housings.
yea
On the road to disaster I cOriginally Posted by zippyflu
Back from the dead!!!
Any pics of the yellow 893 bulbs? I was going to pic a set myself but i would like to see the output. At any rate, ill take them off of your hands if you dont have a use for them 8)Originally Posted by Da_silvagride
Originally Posted by AVERAGE
Sorry I don't have any pics of them. I actually have blue ones at the moment, but my firend is the one with an 8g that has the yellows. They aren't that bad, but I want it to be brighter like the Lexus IS300. Enough to distinguish the Headlights being white/blue and fogs bright yellow.
Hope this helps.
glad my tutorial is helping people. i feel speshul lol
I just wanted to ask if there was any other way to rewire the fogs (tapped to the park lights)? this seems really complicated..Originally Posted by pinoyesv6
with this mod will the foglights automatically turn off when the headlights do like usual or do i have to manually do it everytime i get out of the car.. ?
MARCH 2009 COTM
fully interfaced with Xbox Media Center. learn more at www.xbmc.org[/b]
Ballin' on a budget
Just make sure that you use grommets when routing wires thruogh the firewall.
