ok man... from what i know, that green wire you pulled off is the negative wire on the set. there is a green and then there is a black. the black wire is in 1 end and the green is on the other. there is 3 slots in the connection so just make sure that there is a wire at each end. if you look at the connector, you will see a little metal clip in there. make sure its touching that. i think you should be find after that. for your other problem, im not sure what you're talking about so ill leave it up for someone else.
