if you haven't done it before, then replace the water pump if doing the timing belt
can anybody add to the list of what needs to be done?
hoses
belts
oil & oil filter
air filter
timing
transmission flush
spark plugs & wires
fuel filter
water pump
what else??
~Lady Driven~
the 120k maintenance is almost the same as the 60k service
A dealer recommended 60 or 120k service is usually as follows:
-Oil change
-Oil conditioner
-Induction cleaning
-Fuel injection service
-PCV valve (if equipped)
-Spark plugs
-Spark wires (If equipped)
-Timing belt
-Drive belts
-Water pump
-Cooling system flush
-P/S flush
-Transmission flush
-Brake inspection (turn rotors/drums and/or replace pads or shoes if needed)
-Brake system flush
thanks guys...
yeah...i know 120k is almost like 60k...just was thinking what parts i would need...head got stuck thinking...
