you will need a 1/2 spacer to clear the starter..also longer studs...but other than that you should clear the a/c lines...only problem i know is the starter, and the 1/2 inch spacer should take care of that.. but i heard that cali had to use 2, 1/2 spacers..im in the same boat as i wanna buy an evo 8 manifold with a 16G..
edit- this is info for an 8G galant...not sure on the 7G.
