you want a fwd box or 4wd drive box?
Wich gearbox will fill an galant with engine code 6a13?
i want a fwd
umm sorry cant help much then,
but the box from a 6a13 n/a sohc will fit,
and so will the boxes from cars that have a 6a12,
and the FTO gear boxes will fit,
head over to www.clubvr4.com
as we have a few FWD 6a13TT powered cars, and the 6a13 sohc fwd's
and someone there will be able to help.
i dont know the numbers for the fwd's as both of mine have been 4wd's
from wich car can i get the 6a12 and 6a13 na sohc??
a JDM 92+ galant, or 96+ legnum,
Would the transmission from a 6A10 ('92-'98 Lancer) also fit?
i would assume so,
as far as im aware all the 6A's share the same bottom end design,
but i doupt it would be up to handling the power/torque of a 6a13 TT or Sohc
hi guys, just wanted to know if anyone here knows the required number of liters of oil for a 6a13 engine. thanks!
im planning to use 5w-30. would there be any problem with the internals on cold starts?
4 liters from what I recall..
OT.. Gly I didn't know you're also here :D
thanks for the inform naurhtika03. btw, nice engine your have there. hows the fuel consumption?
thanks 6a13 for teh info. btw, what program are you using?
thanks! i will try to look for that program. looks like its realy useful.
ACan i install the headers from a 6a12 in a 6a13 engine?Will this fit?
The 6A12 ones are more restrictive, why would you want to ?
1995 FTO - V6 Mivec 200hp
I only want to now it. Is it possible that the headers from the 6g72 fits the 6a13? Nobody has headers for the 6a13 engine.
