Thread: 7Gs with rear discs WITHOUT abs, need favor!
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 45
    12-17-2002
    Sherman Oaks, California
    4,304
    7Gs with rear discs WITHOUT abs, proportioning valve situation
    So after doing the rear disc swap, the proportioning valve (proper name pressure metering valve) is still different. 7Gs with rear discs apply more pressure to the rear pads than they do drums, and lately i've been feeling it. the car still feels front brake heavy, and i know it can be more balanced. i can't just swap one from a GS because they have ABS and the valve wont fit.
    so i need a favor. i need a VIN to put into mitsuCAPS from a 7G with rear discs without ABS. did these even exist? if someone feels gracious enough, i would sincerely appreciate it, and will try not to give your VIN to my chop shop for all my car jacking scams.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    if i remember correctly, the GS is the only 7g in the states to have rear discs.
    how about maybe a 2g eclipse?
    08-01-2002
    Keokuk, IA
    8,348
    Id think a 2g Eclipse RS/GS or GST without ABS would have the right valve.
    12-17-2002
    4,304
    Quote Originally Posted by seth98esT View Post
    i thought about it, but i dont want to take the chance of it not fitting for some reason. there's a good chance it will though....
    i've seen a couple 7Gs with rear discs that weren't GSs, but they had ABS.
    1994 Galant GS 5spd
    no the only stock rear disk equipped cars are the GS.
    and i know what your talking about. i can feel it too
    Quote Originally Posted by polishmafia
    You want real respect from those fools? Don't race him. Tell him racing is a sport left to young boys who are still waiting for their balls to drop. Then while he's out racing, fuck his girlfriend in the ass, take pics, and leave them on his car while hes at school.
    12-17-2002
    4,304
    i swore i saw one at Vons a couple years ago, it was an ES. that could have also been the meth.....
    so what we're coming to is that we're screwed.
    1994 Galant GS 5spd
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by peanotation View Post
    I know exactly what you mean. Thats why I went dual piston fronts so it balances the the rear end, and it did.
    Build Thread
    Proto
    the GS and early GSTs didn't come with ABS. I'm using 7th gen calipers on my rear of the 2g.
    i got dual piston fronts but it is still unbalanced
    12-17-2002
    4,304
    wouldn't.....dual piston calipers....apply more pressure...thus making it more imbalanced?
    also, i assumed that if 7Gs with rear discs were ABS only, the eclipse would especially be the same way, but i'll check on that, thanks proto
    1994 Galant GS 5spd
    proto's car dosen't have abs. i have driven it and i like the balancing of his brakes.
    alot if GS-T's didn't come with abs. it was an option only. GSX are all abs
    Proto
    You should drive the car with 60 trim in it now. Boost is cut up >:]
    09-20-2007
    Sea Isle city, NJ
    4,098
    I have EBC Red Stuff in front and stock pads in the rear. It takes a lil tab on the pedal to stop the car.
    Build Thread
    12-17-2002
    4,304
    so because they're dual piston, they require more brake pressure, thus letting the rear brakes bite more than normal before the fronts....correct? or do they bite harder at the same rate of the single piston...thus furthering the imbalance to the front?
    1994 Galant GS 5spd
  15. #15
    09-20-2007
    Sea Isle city, NJ
    4,098
    That is correct. Thats why I have stock pads that bite less in the back, and red stuff pads that bite really hard in the front, so its balanced. Dont know know if its balanced to the stock ratio, but since Ive done this Ive never been able to lock the rear.
    Build Thread
  16. #16
    12-17-2002
    4,304
    yeah i think getting the correct ratio is impossible without an oem setup, but you're probably really close. i just really wish the rears would bite more cause i feel it ALL the time, lately more than normal as i can feel the fronts doing a lot of the work.
    maybe time to go to the eclipse junkyard....
    1994 Galant GS 5spd
  17. #17
    Experienced TGC Member Blue Ice's Avatar
    07-31-2002
    Kansas City, MO
    1,244
    I have dual piston fronts with EBC Red stuff, stock rears andbasic pads and I haven't noticed any imbalanced braking
    (then again it's been almost a year since i drove it)
  18. #18
    Proto
    Peano I'm running run of the mill Autozone semi metallic pads, can stop on a dime and have very little brake fade. Front dips a little more due to the dual pot calipers but overall my brakes are balanced. What I have below.
    * 3000GT SL Dual Piston Front Calipers
    * 7G GS Rear Calipers
    * RRE Stainless Steel Braided Brake Line Kit
    * GSX Slotted and Drilled Rotors
  19. #19
    i noticed that my peadl goes further down now.
    before i only had a 1" of brake pedal travel.
    now i have 2.5" i never need to press the brakes more tha half way.
  20. #20
    12-17-2002
    4,304
    so i got a VIN off autotrader for a 95 GST w/ rear drums w/out ABS...gonna be about $65 for a brand new oem proportioning valve from mitsuparts.com. before i order it i'm gonna run to the local mitsu yard (literally hundreds of 2gs) and see if i can pull one and save some money.... hopefully this works, will update
    1994 Galant GS 5spd
