Yellow bushing? The only thing yellowish that I know of are the bump stops, so I think that is what you are looking at. I would be more inclined to check control arm bushings or sway bar bushings and sway bar end links. Is it the front or the rear? If it's the front, the front struts don't have bushings. They do have spring pads at each end of the spring, but I doubt they are worn, but if they are, I doubt they would cause a rattle... possibly a squeaking sound.
