The dimmer control has three wires on the plug side (the thing you disconnected from the bezel) you want to tap into two of these wires; one for ground and one for power. You can use tap and squeeze connectors from radio shack, you can cut the wires and splice, you can stuff the gauge wires into the connector, or you can gently strip the insulation from the wires in the dimmer switch and connect the gauge wires that way. It's up to you. The object is to get a solid connection to the gauges from the dimmer switch. Hope that helps.
Chip
