Alright So I was able to get my LICP together and now have completed my intercooler setup :).. Um I moved on to the the fuel pump and started to replace my old one to with a 2g Turbo eclipse fuelpump.
My questions.
1. I got the nut connection at the top ready to be removed but as I screw the line off it becomes kinked to the point were it looks like the black tube is going to break :(
Should I keep twisting it off or remove the bottom nut connection as well (going to that long line)?
2.Also when installing my LICP, I was unable to get it to fit with the larger radiator fan so I just took it out :) Will this cause the other fan not to turn on?
