-Clean the inside of the throttle body
-Make sure the throttle cable is snug and not loose
-Make sure you dont have any leaks in the intake system(loose pipe, hole in a pipe, breather line not attached)
-Check the trans fluid
What does it idle at in Park? You can raise the base idle with the BISS screw a tad.
