Two things come to mind here. 1. Faulty oil pressure sensor OR 2. Oil pump is going bad. Hope this helps you out. Good luck!
For the last few days my oil pressure light flickers if I take a corner in neutral or with the clutch depressed. It does not happen going up or down inclines and there is plenty of oil in the engine. Any ideas?
the terminal might have oil/crap on it...... try cleaning it?
Check your oil levels...you maybe be low on oil.
Check the terminal and connector to the oil pressure sensor...clean if needed.
If you oil level is good and you checked the terminals..then its most likely a bad oil pressure sensor.
Its rare that a oil pump goes bad...so i doubt thats your issue.
Plenty of oil. Cleaned all terminals and light went away till yesterday so thought it must be the sensor but when I was removing the cable noticed that the wire going into the sensor was dodgy looking. Replaced cable and all seems well. Thanks for the help.
i replaced my oil pressure sensor like 25,000 miles ago and now i'm flickering again.. maybe i should check wiring.. can anyone advise where it's located?
nm found it here
https://www.thegalantcenter.org/show...ressure+sensor
