Disconnect your negative battery cable. Take a regular test light, and put it in between the connection of the battery, and the car's negative cable. Make sure EVERYTHING is turned off, and the doors are shut. See if the light lights more than a TINY glow. If it does, and I bet it will, you have a DRAW. A draw will drain your battery when your car is at rest, and you must locate the source of this draw. Pull out each fuse 1 by 1 until the test light goes almost dark. Make sure the domelight is not lit, because that will show as a draw too, of course.
Once you have found th fuse that is guilty of drawing, look in your manual to see everything that that fuse is responsible for, and eliminate them 1 by 1.
