NEWBIE
6x9 issue
anyone got pics of 6x9s mounted on there parcel shelf? installed mine yesterday, and now generating interference - could this be due 2 the metal frame of the parcel shelf?
any 1 got a brill solution as its doing my head in lol
cheers :)
Member
What year galant? and what is a parcel shelf? (rear deck?)
NEWBIE
2000 galant , by raer dect u mean shelf u can see thru rear window - in which origional speakers sit lol
soz diff words in diff countries lol
what do you mean interference?
If you mean interference, like you can hear a fuzzy sound while excellerating. That useally means you have a bad ground some wheres. If you have An amp. hooked up to them make sure the ground wire is no longer then 12 inches. And if they are only running through the Radio only then make sure it is attached to a good ground.
NEWBIE
will checkk 2nite see if grounding properly cheers :)
NEWBIE
issued solved for now lol - all speakers out the car after 1 my amps decided 2 internally combust :( so spare amp n sub will be going in till funds are sorted :) on a positive side no interference when i plugged 6x9s in earlier, so all good :)
