Thread: 04 Mitsubishi Galant Engine & Trans
Showing results 1 to 9 of 9
    does the 04 Mitsubishi Galant Engine 2.4L & Trans fits in a 7G?
    :D
    only a cuestion!!
    i see a sheap swap of that car,!
    __________________
    never going to happen
    1996 galant s
    might as well swap it with an evo
    uhhhh...... Whats a 9g???
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    The evo motor wont swap over either..... It wont work becasue the motors are turned 180 degrees from the 7th gen. They are the same exact motor, everything is just turned. There is no diff in performance so why would you want to swap it??? If you wanna swap the motor go with a 1st or 2nd gen eclipse motor but you will have to do a good chunk of wiring.
    Quote Originally Posted by skrap View Post
    LIAR! Evo head will fit.
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    No it wont
    Build Thread
    08-01-2002
    Keokuk, IA
    8,348
    You cant say it wont fit. You can say it is not a direct bolt in. I have seen a 5g Mirage(same motor orientation as the 8g) do a 1g 4g63t motor swap. Lots of welding and fabricating involved.
    So, the money you save on that motor and trans, you will spend 10x that in custom fabrication to get the motor to bolt in ;)
    09-20-2007
    Sea Isle city, NJ
    4,098
    I know what youre saying, but Evo8-9 head on DSM motor is a no go....thats what I meant
    Build Thread
    ok. thanks XD
    __________________
