your only getting the front wheels?
I found these for sale locally for 150 with used tires for the 5 lug swap. do you think these would clear the evo 8 brembo's?
[IMG][/IMG]
2003-2007 Infiniti G35 Front Wheel Size/Offset: 17x8, offset is 33mm
Bolt Pattern: 5x114.3
1994 Galant S. 90 Percent GS.
no the whole set with tires. thats the actual pic of the set.
Those are off an Infiniti WITHOUT the Brembo brake package, so I'd doubt they'd fit over the EVO's brembos (assuming that is what you are using).
Are the offsets staggered from front to back? ebay has 1 that is a 7.5" wide and offset of 30, and 1 thats 8" wide with offset of 33. Makes me curiouse what the differences are between the two. says there off the same year and its the same style. What would the offset need to be? I dont have the brembo's on yet just trying to get the rims and tires now so I can swap out the 99 gst suspension I got.
wondered why you said that, ok so your right, the fronts are 7.5" wide with offset of 30 and the rears are 8" wide with offset of 33. thanks for all the info. but still dont think they'll clear the brembo's? looks like i'm going to have to call my buddy with the evo 8 for a test.
they will clear, but the center bore of the wheels need to be enlarged.
So they need to be machined to fit the center hub portion that sticks out? Ok, thats not a problem. Ive got one of those honing tools that will make quick time of that, then there going into the paint shop for a fresh coat of black chrome powder coat.
