second picsie isnt workie
Well. I have a 1g that im getting rid of so i pulled the prop valve off of it and the car doesnt have ABS. Looking at the 7g and 1g prop valve they are damn near identical. If it works there will be no need to make new lines to go to the master cylinder because they route the same way. Ill show you guys pics. IDK why this has been overlooked. Are the flows different on the 1g prop valve or something?
7g: (thanks for the perfect pic mitch)
1g:
it works on my computer. let me find another pic. FIXED
wow that looks the same. let me know how it goes. if it works and all.
what model is that from? the 4g63 n/a?
its from a 90 turbo fwd. Those pics came off of the net so idk what that one is from. The one i have is identical
im going to the j/y tomarrow. Ill see if I can pick up a few
I get ONE!!!
maybe
Honestly id be shocked if it didnt work. This would be so much easier than making new lines its not even funny.. Its a direct fit.
So i did some measurements on both prop valves and they are EXACTLY the same size. The flow for rear and front are exactly the same.. So hack away with this guys... Sure beats the hell out of running new lines which would be an absolute pain in the ass.
good find. But you don't have to run new lines, just rebend them.
another option is the 1g Diamante non ABS prop valave. Its even better cuz it already has the dual piston fronts
I guess this means I should have switched my proportioning valve out when I did my conversion huh? Oops.
so a 1g prop valve will work? if so i have both a 1g and 2g sitting and i havent done the swap cuz of having to redo the lines as im afraid of messing one up. the 1g would be so easy to do it with
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
I did the measurements and they are exactly the same size. As long as its not ABS.
2014 Lancer Evo GSR
2014 Lancer Evo GSR
