What kit did u use? Works or ?
the lowering spring is finally installed,finally i can post some pic now i cant post pic before cuz my computer is down,,,
The drop looks good but dang those wheels look tiny on the 9G.
looks really good but i would definately go with a bigger rim
imma gonna sell my rim and get motegi 19 inch rim..thanks guys for the inputs....
Make sure you add pictures of your ride in our official 9g picture thread!
19s or 20 inch WHEELS (not rims) would look the best.
i might go up 19s soon,but im afraid that the tires will rub in the fender,,but down the road will to go up for 19s WHEELS,,,
how to put pics in the 9 g threads???
if you guys dont mind any sound setup suggestion??thankyou
are you the one who make the box or you bought it custom made?? cuz there is one custom shop where willing to do custom made fiberglass layout..im thinking like 2 subs and amp,,one on each side and amp in the middle,,hes gonna charge me 500 for it including installing it but the components is out of my pocket..
Tirerack.com says you can put 19s on that biznitch. You should be good. I think another dude on here has 20s too with no adjustments needed. I'm not too confident about 20s and how that would work out.
I believe that Ralliarts had 18s stock so you can probably do 19 or 20 without issues as long as you get right tires and wheel specs.
9th Generation: (listed in italics are sizes that best fit)
Original: 215/60-16 (26.15") **Original DE & ES sizing**
Plus Zero: 225/55-16 (25.75")
Plus Zero: 225/60-16 (26.62")
Original: 215/55-17 (26.31") **Original SE & GTS sizing**
Plus One: 225/50-17 (25.85")
Plus One: 215/60-17 (27.15")
Plus One: 235/50-17 (26.25")
Plus Two: 235/45-18 (26.33") **Original RalliArt sizing**
Plus Two: 225/50-18 (26.85")
Plus Two: 245/45-18 (26.68")
Plus Three: 235/40-19 (26.40") **Recommended upsize fitment
Plus Three: 225/40-19 (26.08")
Plus Three: 225/45-19 (26.97")
Plus Three: 245/35-19 (25.75")
Plus Three: 245/40-19 (26.71")
Plus Three: 255/35-19 (26.02")
Plus Four: 225/35-20 (26.20") **Recommended upsize fitment
Plus Four: 235/35-20 (26.44")
Plus Four: 245/30-20 (25.79")
Plus Four: 245/35-20 (26.75")
Plus Four: 255/30-20 (26.02")
I would go 235/35-20 or 235/40-19 :)
