Thread: neon lights
Showing results 1 to 4 of 4
    neon lights
    Okay I've had my neon lights sitting in my car long enough.. I tried wireing them into the fusebox before and all was good untill my foot ripped hte wires out breaking the fuse spot for my cig lighter so i cant use my radar detector... anyways.. could someone give me instructions on a good way to wire my lights in??
    I have 3 neon tubes, a set of street glow pedals and a 12v relay for them and a switch.. any help would be great.. thanks.
    -jimieo
    I hardwired mine to my capacitor for my system. It takes some time but well worth it. To keep from ripping the wires out you are gonna have to put them up and out of the way, taking the lower dash panel off was easy. Full underbody kit and interior neon have both been run that way
    wire them in to a switch with 12V constant from the battery. just don't for get to shut them off. or wire them switched through an ignition on power source. or take them out cause the trend died almost 8 years ago
