Welcome to TGC.
We need more info from you. I4 or V6? Is the check engine light on? When did this start happening?
Hi all
I have a 03 galant. it has a weird problem lately...It can not start when it's warm..
I can start the car in the morning..but after drive for 10 -15 mins turn it off i can't start back on..i have to leave the car there for like more than 6hrs or when it's cool enough then I can start it back on.
I changed starter and it wouldn't help..
I'm thinking the main relay, but i need some advices..thnx
Welcome to TGC.
I have an I4 and yes the engine check light is on..it was just fine after one coldest day...it was like -15 degree..After that the car begin thsi problem...I replaced new battery and starter...At first it seemed OK...but then when the car gets warm I can't start the car back on...
I took 2 auto repair shops..They checked everything..and they couldn't find a thing..everything looked normal they said..
Hmmmm......... I once read oxygen sensors dont respond till they are at like 600 degrees... maybe this could be your problem. once the oxygen sensor warms up it kills the car. Just my ignorant guess though.
When you say it wont start back up, what exactly happens? Does the start crank and turn the engine over and just not start? Or does it not try to crank at all? Those would be two opposite diagnoses.
When you went to the auto shop, did they check the CEL with a code reader? Is it overheating? Do a compression test.
You need to get that code scanned asap. If you took it to two shops, and neither scanned it for you... never go back to those places again.
Well your best bet will be to get those codes ASAP to see what is wrong. Members on here will be able to help you more if you get these for them.
02StratusRT and 00EclipseGT
Yeah bro.. there are some guys here who can help you alot...
Go to a good shop, maybe even a dealer and get them to scan the car, write down every code you get, then come back and post them all on here and you'll get your answer.
eletrical problem some where's. As the car warms the part/piece expands causing a bad connection. then once it totally cools your getting a good connection which allows it to start. Also get the code read, autozone rents the readers out. They can still be used even if the car is not running. all you need is the ignition in the run position and a little bit of power still in the battery.
Good luck.
replace the camshaft position sensor
my brothers protege had the same problem car wouldnt start after it warmed up. we changed crank and cam sensors but it didnt help.(but thats a good possibilty)
but after changing the coolent temp sensor it ran good with no problem.
is your car drinking alot of gas? does it hesitate or stumble on wide open throttle(peddle to the medal)?
because he has the same problem. at least he searched before starting a new one lol. im pretty sure im right on the problem fix too.
