NEWBIE
9g Fender Replacement
Hey guys I'm brand new to this forum, so there may be a spot that outlines my following question.....
So yesterday (11-22-10) I was on my way to work and hit a patch of ice and slid into a parked car, causing a lovely dent in my passenger front fender....I am debating attempting to pop it out or replacing the fender...anyway, my question is: Has anyone replaced a fender on their 9g? I'm just curious if it's worth the trouble or not. Also, I googled it looking for a guide to do it and was not able to find one...maybe someone knows where I can find a step-by-step guide?.... Any input would be greatly appreciated!
Member
its not that hard I took apart my drivers side fender. inside the wheel well there are many plastic screws. once you get the black plastic part out you will be able to see the bolts. theres also three under the hood. one is hiddin under neith the plastic trim peice near the window. All you need is a ratchet and time.
