alright i checked around and need a little help first when using the g4js head w/ evo adjustable gears and im using the evo belt i lined it up to the stock marks and it seems off but i remember seeing somewhere that it needs to be either advanced half a tooth or retarded by 4 degrees.
my second question and i found a thread about this and bumped it but got no response is there a way to hookup the speedo when using the evo ecu in a 02 w/ m/t that actually works?
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
large fmic w/ cx racing intercooler pipes
wrx injectors @ 100psi fuel pressure
