Yea but what do you use so the balancer doesn't move as your tighting the center bolt!!! Anyone?
you have to torque it down to specs with a torque wrench.
I can't remember exactly what I did, but i'm pretty sure I just stuck a screwdriver in a hole on the balancer itself, and wedge it against the bottom of the block, on top of a oil pan bolt, so I didn't bend the oil pan itself, and then just torqued it to spec. but I have an 8g
i think someone mentioned before about using a allen key in the hole.
