HAs anyone tryed the adjustable control arms from socal.just want some reveiws
has anyone bought these yet? and if so what are ur thoughts?
link?
You must be talking about the rear trailing arms made by Megan racing. I've never heard of other adjustable control arms, at least not for 8g.
The Megan Adj. arms adjust the caster, and maybe some toe, but to have such a fine tuned rear suspension and spending that much money on them is pointless.
i think he is talking about these ones
http://www.socalautowerks.com/fp1.jpg
These are the rear toe eliminator arms that Cali makes. These are good.
The benefit is that they use normal bolts instead of the off centered "toe" bolts that usually rust out very bad. The heim joints on both sides makes them more flexible than the stock ball joint style arm. And since these are almost solid, they are stronger than the stamped steel stock ones.
