why would u want to do that? just seems like something ricers do just to fool each other into thinking they got a performance exhaust.
9gen i4. Has anybody thought about making a short exhaust and dump it after the oil pan or dump it after the rear axle and if u have wat does it sound like
5spd swap
full custom body conversion
18x9 Works VS
Big 16g evo3T next project
more then most likely itll sound obnoxiously loud i have an exhaust leak right around that area (not even and open pipe just a leak) and if your outside the car you cant even hear yourself think.
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
large fmic w/ cx racing intercooler pipes
wrx injectors @ 100psi fuel pressure
It'll sound like a chihuahua using a fart can... don't be that guy.
Effort and courage are not enough, without purpose and direction.
oooh trust i learned from a wise modder shortdogg2k05 im goin with the full catback and headers
Sounds like a ferrari on my car.. Video coming soon..
Rofl sounds neat
it sounds alright so i will do headers megan or magnaflow exhaust depends on how the pockets look but what headers are u using
if you dont wanna be obnoxious and still get a great sound. get a res delete. midas $50 bucks weld it a straight pipe where the resonator was. i just got mine done a couple of weeks ago and it sounds pretty damn good. also saves your that cash.
(p.s. i do have the 3.8l v6 with mivec heads)
9g Baby!
Ya, the res Delete sounds good, I am going to get mine done this weekend.
I've been thinkin about getting a resonator delete, it's only $30 at this local muffler shop, so I'll probably do it eventually, but I'm not sure if I wanna do that or just save the gas money and spray some water on my glasspack haha.
I got a Res and third Cat delete and put in a used Res. It sounds awesome!!
