Thread: sudden break down!
Page 2 of 2 FirstFirst 12
Showing results 21 to 37 of 37
  1. #21
    08-13-2008
    Waterbury, CT
    3,331
    ebay or junkyard man
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  2. #22
    08-13-2008
    Waterbury, CT
    3,331
    2014 Lancer Evo GSR
  3. #23
    I got mine for 170 free ship on ebay
  4. #24
    well i have a motor that was in a 96 and it still has the cam sensor outside the distributer.. so would it be more cost effective to get a 96 and up ecm with harness?
  5. #25
    08-13-2008
    Waterbury, CT
    3,331
    no ur car isnt OBD2
    leave it the way it is or you need to get more sensors and stuff. just fix the issue at hand now
    2014 Lancer Evo GSR
  6. #26
    my engine has all those extra sensors because of my engine swap from a 96. but that would fix the issue because the 96 and later distributors didnt have the sensor in them it is by the timing belt cover.
  7. #27
    08-13-2008
    Waterbury, CT
    3,331
    there is only 1 sensor difference on the motor itself as the crank sensor is on the driver's side by the crank and not in the distributor.
    please dont make this harder than it is and just get it running
    if the pump is good then its the distributor, any CEL or anything?
    2014 Lancer Evo GSR
  8. #28
    mine has a barometer sensor on the intake as well.
    CEL?
  9. #29
    08-13-2008
    Waterbury, CT
    3,331
    check engine light.
    pictures of your motor as well. the sensor on the top on the intake mani cant be hooked up to anything as its not on a 94 or 95 car.
    2014 Lancer Evo GSR
  10. #30
    nope no check engine light
    and it isnt because no plug for it. lol i learned alot from doing the engine swap.
  11. #31
    08-13-2008
    Waterbury, CT
    3,331
    the intake manis are the same besides that little sensor.
    you werent losing coolant or oil were you prior to this
    2014 Lancer Evo GSR
  12. #32
    coolant and oil are fine.
  13. #33
    08-13-2008
    Waterbury, CT
    3,331
    then a really say distributor man. its electical it would just go like that
    2014 Lancer Evo GSR
  14. #34
    the sensor thats in it went bad? or the distributor itself?
  15. #35
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Oh I see now. (about the other thread)
    Its a whole distributor assembly. Besides the rotor and the cap, no other parts are available.
    Very easy to check for spark. Pull a spark plug out, attach it to the spark plug wire, ground the threads and have someone crank the engine. you must see spark. If you dont then most likely the distributor is shot
    Build Thread
  16. #36
    ok ill take a look at that lol
  17. #37
    distributor is A ok. however the cap looks horrible so im gonna do a tune up. and see if thats the problem
